Stripped bolt on intercooler to turbo
Car Info: 09 WRX Stage 2
So I had a small job done by a local mechanic, he took my grimmspeed AOS off so I can pass smog. When he put the intercooler back on he stripped the threads on my turbo.... *******.
So I went to dealer to see if they can do anything and they said all they can do is install a new turbo, i dont have $1500 to drop on a new turbo.
I am planning on tapping it a little bit larger and then running a bolt and nut on it.
Any other ideas?
Any other ideas?
there are plenty of ways to repair this issue. First you can try to rethread/chase the threads on turbo liek silverbullet415 says, another way is to use a timesert onto it. I prefer timeserts over helicoil just cause the flange where your intercooler bolts onto is opened.
same thing happen to me...grab some grade 8 bolts, washers, and nuts and your done. You will never have to worry about stripping them again. Don't forget some anti-seize. Over time the bolt heads might just crack off while trying to loosen them up (if your sticking with the stock set up).
bringndefinitio
03-17-2006 03:53 PM
Dinko81
12-30-2003 04:52 PM
awd4ever
11-10-2003 01:17 PM
