General Tech / How To's / Installations Technical discussions about the USDM 2008+ WRX and WRX STi.
exhaust question
Old 01-17-2015, 12:06 PM
subiekid916's Avatar
Car Info: 2009 subaru impreza 2.5i
exhaust question
I have a 09 2.5i na impreza that I'm trying to get a front chassis brace in but can't due to piping and a cannister looking thing... does anyone know whether after the headers on the bolt in mid pipe if the canister is a resonating chamber for sound or if it's an actual catalytic converter with no o2 sensor?
subiekid916 is offline
Old 01-17-2015, 12:10 PM
This is in between the headers and the exhaust and bolts in... can I delete
Attachment 91754
Old 01-17-2015, 12:42 PM
silverbullet415's Avatar
Doesn't look like a cat, take a farther away pic of the whole header setup.
silverbullet415 is offline
Old 01-17-2015, 01:17 PM
Unfortunately can't right now due to the fact I'm at work I will try to take a pic on my lunch break
Old 01-17-2015, 05:16 PM
So this is the best I could do since the cars lowered and I'm at work this is from the front of the car my headers are wrapped amd have the cat and o2 sensor attached to them and the second canister is just there with no sensors
Old 01-17-2015, 05:48 PM
Looks like a resonator to me, it would have more shielding on it if it was a cat. But I'm not 100%
Old 01-17-2015, 05:59 PM
JourdanWithaU's Avatar
It's a cat. Resonator is further down.
JourdanWithaU is offline
Old 01-17-2015, 06:13 PM
Half my sheilds were rattling.... can I delete it with just a straight pipe? Would it mess anything up? Or maybe relocate it?
Old 01-17-2015, 07:16 PM
You could remove it but smog will be an issue every two years, moving it down won't be a issue.
Old 01-17-2015, 07:32 PM
How far back can I move it? If I tale it out I will put it back in before smog... would it cause a cel?
Old 01-17-2015, 07:41 PM
If there is no sensor after I don't see why
Old 01-18-2015, 09:27 PM
Hold would it affect my back pressure though if I ran just a 2.25 inch piping from the headers?
Old 01-18-2015, 09:59 PM
It would shift your powerband up. (Loose bottom, gain top.)
brucelee
08-01-2009 10:59 AM
Skatemur
10-01-2004 12:56 PM
dj_kiyoshi
15
07-24-2004 12:36 AM
2K3WRX808
06-28-2004 01:40 PM
legacy2003
06-08-2003 04:43 AM
Quick Reply: exhaust question
