help with ej25 rebuild?
#61
budget really. I dont want to put $$$ in the RS. ill be doing that for the STI although i did some more looking around and $60 more for full Group-N why the hell not. and the fact that they are designed by STi. even better.
update:
still no luck with case bolts in water jacket
update:
#62
Car Info: 04 WRX Wagon, 06 Forester XT, 99 Legacy Sedan
Hmm... Is it because they are corroded or because they are in there really good?
What have you tried so far on the bolts?
I used my 1/2 HF breaker bar (the big one) and had no problem at all. But that was on a motor with only 114k on it. I am sure they would break loose if you had something similar with a cheater bar over it.
#63
YOOOOOUUUU again....hahah JK i do appreciate all the help!
I tried taking a 1/2 breaker bar and extention with 12pt at the end. the extension stapped at the socket. i also took a couple quick light taps with the air compressor but didint want to do much more with the risk of damaging the aluminum case.
Oh, and I have 260,000 miles on the block....
#66
Nothing else you can do besides get a stronger extension and put a huge cheater bar on it. 17" breaker bar with a 3 foot cheater pipe should do the trick.
I will buy the block off of you if you decide to toss it.
#67
Rebuild Update:
Finally was able to remove oil separator plate and remove the last two pistons. I noticed some scuffing in the #1 cyclinder wall where piston skirt would ride. Ill know more when i have the block split and bearings in hand.
Posting pics tonight
#73
FINALLY split the block this past Saturday. spent about 20mins each bolt shocking them every angle i could. used a 25" 1/2 drive breaker bar to adapter to 3/8 extension to 3/8 12mm 12pt. They creaked and gave way!
take a look at the pics! valve stem leak shows bearing damage. taht with the combination of bearings with 255,000 miles on them!
^Heads back from sshop
^made myself a little engine assembly station not perfect but the amount of crap the tree above donates....no good.
^Bolt mapping
SPLIT!
^Bolt mapping
SPLIT!
