05 RS needing a new head gasket
Car Info: Silver 05 Wagon
Hi,
I just back from my 130,000 oil change and the Subaru shop is saying I have a very small oil leak on the drivers side head gasket. Price to fix is $2900 which includes a timing belt replacement. Is it that hard to do by needing to remove the engine to change a head gasket?
Jim
Jim
Car Info: 04 FXT 6-Speed, 02 WRX(Sold)
It can be done in the car, video of it somewhere, just a pain. Might verify its head gaskets and not valve cover gaskets and check your pcv to make sure it is working.
not hard. i pulled my 03 RS engine at 255,000 miles due to a blown head gasket. pulled engine and tore down entire block. doing a complete rebuild. granted you dont have to do a full overhaul, but these engines are not hard at all to pull. and YES, tehre are videos, DIYs as how to R+R HGs without pulling. not my prefered method, but if you move evrything aside, its doable. GL!
Thanks, I went back to re-read what Subaru wrote down;
" Recommend replacing the head gasket with the timing package, $2900. Slight oil leaking from gasket on drivers side."
Now I don't have the means or tools to do any of this work myself, so I'll have to find a shop or bite the bullet and have subaru do the work. There's no oil dripping so I should be ok for a while. My RS has been a good car and never failed me and I'm keeping it.
Jim
Jim
Jim
Jim
This RS 2.5 has been a fathfull car, while not the Blue 02 WRX wagon I started out with it's a keeper. I may have to bite the bullet and have the dealer replace the gasket since I'm no mechanic and have no place to work on the car.
mirraflair
09-24-2005 01:43 PM
mirraflair
09-10-2005 09:55 PM
