Will a stock GR sti tmic fit a GD sti? Well, I'll let you guys decide.
Car Info: STI
Haha... the reason I ask is that I've been dreaming up a splitter for this... of course no telling when I'll have any time to actually make it!
The baby is due on 7/7/11... we're very excited to say the least!
Ron, you know of any good mechanics looking for work?
-- Ed
-- Ed
I don't know but something about that due date seems like lucky numbers to me. You might have to start investing on some BABY ON BOARD stickers pretty soon.
Mechanics, other than myself (homie hookup mechanic and mickey mouse tuner for the broke) I don't know too many that's not already currently working in shops. I think the difficult part is getting a mechanic that you can trust and depend on, which is hard to come by nowadays. How about good ol' Mr. First 11sec sti on the vf39? He's always down. Seriously though(in a good way), I can only imagine that one...... maybe mechanic and babysitter?
Ron
iClub Silver Vendor
You and me both Ed. Having that bigger splitter would also open up possibilities of maybe running aftermarket GR tmics down the line for the older GD wrx/sti owners. It's a good idea so go for it.
Ron
Ron
-- Ed
Hi.
This is my first post. I will do a proper intro but I have to ask a question. The intercooler that was used for the test fit are both USDM models? If not is the larger TMIC similar to the JDM?
Car Info: STI
Left is stock sti tmic(silver hard breather line) and Right is the taller JDM v7 sti tmic(black hard breather line that came from my stock USDM 04 STI)
Thanks,
Ron
Car Info: AW Pig-STI
Further resurrecting this thread, because i just finished this project myself, here are my notes:
Installing a 2015 STi Intercooler in to my 2006 STi.
* bought the 2011 3rd intercooler bracket.
* bought the 2" 90-degree Mishimoto hose
* bought 2x Mishimoto clamps, sized 2.25"
* bought 3x Subaru intercooler bracket bolts [Note, I only ended up using ONE bolt]
* bought Grimmspeed gaskets for the y-pipe and BOV
took my sweet time wrapping the new GR/GV intercooler. If i didn't do this, this swap would have taken 2, maybe 3 hours, tops. I'm no expert mechanic either, but i'm a bit familiar with working on my car.
Except for the obvious of the installation of the intercooler, here are my notes.
* the 3rd intercooler bracket (aka RH Intercooler stay 2) DON'T FIT in the 2006 GD STi. Where it bolts to the motor, the mount for the 2006 A/C lines interferes. Tried to squeeze it under, but then the A/C lines would rub on the mount. Ended up simply hacksawing the 3rd intercooler bracket, so it was "like an extension" of the original STi RH Intercooler stay 1.
Maybe to those WRX owners out there, you'll need the STi RH intercooler stay 1 at the least!
* on my 2006 STi, the Mishimoto 2" 90-degree hose fit perfectly fine. used their clamps too. When fitting it on the compressor outlet, it was easy to squeeze on. Though it appeared there was a bit "extra length", i just shoved it a little deeper on the compressor outlet. if buying Mishimoto clamps, be sure to buy the 2.25" ones, as that has enough clamp range to fit over a fitted 2" hose.
* after figuring out the bracket and the hose, it actually was about as easy as it gets. Perhaps the one part which involved a bit of flexing was lining up the intercooler bolts. Take your time and it will line up...there's quite a bit of movement available if you are patient.
I didn't want to mickey mouse it and have the intercooler held with only one side bolt and the throttle body hose, and using the 3rd intercooler bracket met my objectives.
For those who are really crafty, i suppose a metal plate with drilled holes would also work, but i liked the welded nut at the bottom of the OEM intercooler stay.
Now...on to the problem of the splitter. Open to hearing what others may have done.
Let me know if anyone wants pics of the 3rd intercooler bracket installed, or if you're interested in part numbers...
Ron
mystilexzero
03-15-2010 06:39 PM
Rose21swf
Troll Hall
15
02-24-2005 08:43 PM
