Timing Belt Advice - Quote too high?
Old 06-03-2015, 12:36 PM
FL4T's Avatar
Car Info: 06 AW STi
Hey Guys,
I have an 06 STi with 52k miles. I don't have the mileage to change the timing belt, but I have the years. I was just quoted $700 at the local Subaru dealership. That seems incredibly high. What do they normally go for?
Thanks.
FL4T is offline
Old 06-03-2015, 01:10 PM
Funks's Avatar
Car Info: STI Hatch - 2012
Contact Mert at RBMS Auto Care (Hayward)..
Funks is offline
Old 06-03-2015, 01:23 PM
JourdanWithaU's Avatar
What are they changing? I just paid $876.50 for my timing belt. I had other quotes at $870 and $950.
JourdanWithaU is offline
Old 06-03-2015, 01:45 PM
FL4T's Avatar
Car Info: 06 AW STi
Whoa that's a lot. This is just a timing belt replacement.
FL4T is offline
Old 06-03-2015, 01:59 PM
You want to just replace the belt and nothing else?
I had the Belts, pullys/tensioners, water pump, and coolant changed.
Old 06-03-2015, 07:07 PM
DabiDa's Avatar
Car Info: 2002 wrx
I know this a is dumb question just wanted to make that this price with parts correct? I know the water pump/belt kits run about $350. So that would make the labor cost about $500.
DabiDa is offline
Old 06-03-2015, 07:50 PM
Javirex23's Avatar
Car Info: 07lmtd 6spd wrx eq tuned
You should do the full timing belt service and the water pump and other things around that. And do it ALL in OEM parts. Call some of our local shops and go with the best quote. RBMS, GST,LIC,AA Mmotorworks,FW motor sports just to name a few there are many other good shops. It's better to do it right the first time, than to risk a motor with so little mileage because of 1-200 dollars. My .02
Javirex23 is offline
Old 06-03-2015, 09:26 PM
FL4T's Avatar
Car Info: 06 AW STi
Yea, that's true. Good point.
FL4T is offline
Old 06-03-2015, 09:27 PM
FL4T's Avatar
Car Info: 06 AW STi
To my knowledge its only the belt. He didn't mention anything else.
FL4T is offline
Old 06-03-2015, 11:50 PM
3 hours at $110, $330 for labor.
Timing Kit, $214.15
Water Pump, $125.95
Coolant, $51.32
AC Belt, $65.50
Alt/PS Belt, $17.95
Thermostat, $21.95
Taxes, $49.68
Old 07-26-2015, 07:04 PM
KingJeff's Avatar
Car Info: 2006 Subaru WRX STI
I paid $1200 for an 02 bugeye 5-6 years ago.
KingJeff is offline
Old 07-26-2015, 07:48 PM
CatchMyDrift's Avatar
Car Info: 2010 Forester
That's crazy. I've done the timing belt, all the components and the water pump on any Subaru (wrx, STi, N/A EJ18/22/25) I've ever owned as well as past customer vehicle and it's never taken more than an hour and a half. The NA SOHC motors take about 45 minutes. Shops love to charge "book rate" instead of actual time.
CatchMyDrift is offline
razerx
17
03-03-2015 05:09 PM
puma_man
04-17-2014 11:36 AM
Quick Reply: Timing Belt Advice - Quote too high?
