Oil Cooler Gasket Leak
Old 09-16-2014, 12:30 AM
strictlyJDM's Avatar
Car Info: 2006 Subaru WRX Wagon
134k miles
I have the typical leak by the oil cooler. Ive changed the gasket between the oil cooler and the oil cooler bracket...one week later. still leaking. I just did it again tonight and i believe theres still a leak.
I originally thought I did get a good seal on the gasket but doing it twice. I know i did the second time. Has anyone have experience with the other 2-3?? gaskets that sit higher up on the bracket between the block and the oil cooler?
picture for reference, this is before I changed it out the second time
strictlyJDM is offline
Old 09-16-2014, 01:44 AM
1JavaBlk_in_Sac's Avatar
Car Info: $2000 hawkeye
Wait, you changed the gasket between oil cooler and filter? Hmmm, you mean gasket that comes with oil filter? Check that gasket between oil cooler and engine block, this could be your problem.
1JavaBlk_in_Sac is offline
Old 09-16-2014, 08:25 AM
I've changed the gasket between the oil cooler and the bracket. Twice
Old 03-15-2015, 05:08 PM
SubieDude05's Avatar
Car Info: 2005 Subaru WRX
I have this same problem. I believe there are like 3-4 o ring gaskets in the cooler. I wanted to try the top one first (between block n cooler) and work my way down till its fixed. How hard was the top gasket u changed?
SubieDude05 is offline
Old 03-15-2015, 09:39 PM
BreadSauce's Avatar
Car Info: 2005 Subaru Wrx STi
I there is only one oil cooler gasket dude. Its between the block and the cooler it's orange. There is also one on the oil filter. If you replace both and it's still leaking your cooler itself could be leaking
BreadSauce is offline
Old 03-15-2015, 10:39 PM
awdorgtfo's Avatar
Car Info: 07 UGM WRX Wagon
The 06-07 WRX has like 3 sandwich plates between oil filter and block. Maybe it's leaking from closer to the block?
awdorgtfo is offline
Irish_car_B0mb
02-18-2011 12:47 AM
salvator_rizzo
07-10-2009 04:10 PM
yzercyber
03-02-2008 06:02 PM
depdivr
09-29-2005 10:52 PM
Zoeb2s
12-30-2002 10:43 AM
Quick Reply: Oil Cooler Gasket Leak
