MISHIMOTO WRX and STI Plug-N-Play Performance Aluminum Fan Shroud Kit, 2001-2007
NO SPLICING REQUIRED!
A failed fan can result in overheating and potential engine damage. Protect your flat four with the all new Mishimoto direct-fit aluminum fan shroud engineered specifically for the 2001–2007 Subaru WRX and STI. The Mishimoto Subaru fan shroud kit includes pre-wired factory pigtails for a plug-and-play connection and true direct fit, which eliminates the need to splice into your body harness. This fan shroud is constructed from lightweight aircraft-quality TIG-welded aluminum and has a brushed finish. It utilizes two high-flow 12” fans, which are highly efficient for reducing engine-bay heat and coolant temperatures. The Mishimoto Subaru fan shroud also includes provisions for mounting the factory overflow bottle to the shroud for a hassle-free installation. This fan shroud kit is covered by the Mishimoto lifetime warranty, so you know quality is guaranteed.
Speed Element
07-18-2013 03:57 PM
LGT Mark
11-16-2012 11:14 AM
