LF Front oxygen sensor.
Old 03-19-2012, 04:03 PM
Jimboi's Avatar
Car Info: 2005 sti
Hi, Im looking for a front o2 sensor obviously. but i wanna know where i can get it at the best deal? any help? thanks
Jimboi is offline
Old 03-29-2012, 08:27 PM
banned
C89ZX7R's Avatar
Car Info: 2004 STi
Its not called an 02 sensor. The car has one 02 sensor and one Afr sensor. The 02 is in the downpipe and the Afr sensor "wideband sensor" is in the manifold collector before the up-pipe. If you still have the factory manifold heatshields then I suggest you get a dremel as the heat shield will need to be cut out before the Afr sensor is removed. Buy an 02 socket, dont use pliers on it.
C89ZX7R is offline
Peaty
05-30-2008 09:58 AM
knightsnke
04-23-2008 05:55 PM
diz
Subaru OEM Parts For Sale
07-09-2007 03:41 PM
diz
01-24-2007 05:12 PM
imprezapilot
01-06-2004 10:22 PM
Quick Reply: LF Front oxygen sensor.
