EWG question, when should it open?
Hi,
I have a tial 38mm vband wastegate. I am installing the .9 bar spring, which is roughly 13.05psi. Should the wastegate begin to lift at .9 bar or be fully open at .9 bar? I brought it to work today to test and am noticing movement at ~10psi.
Thanks!
Derek
Thanks!
Derek
Sounds like its working well. Had similar setup and with the boost line and tune you'll be good to go. My tuner had the boost controller set so the ewg does its job and holds the levels for the turbo for the optimal tune for what your look for (ie high numbers, daily driver, or autox etc.)
dmagda3
11-09-2012 05:56 PM
verc
03-15-2011 06:26 PM
BBKG79
04-21-2009 04:27 AM
gesundlich
03-17-2009 01:40 PM
