does anyone know the VF36 turbo specs?
Old 10-24-2006, 01:50 PM
azn_ryder02's Avatar
Car Info: 2007 Satin White Pearl STi
tid bit: the VF36 turbo is the twinscroll turbo that comes stock on the STi spec-C i was wondering if anybody had the specs or know anything about this turbo in terms of A/R and flow rates and/or comparible size to the stock VF39 and compared to other twin scrolls like the APS tsr70
im very interested in this turbo b/c ive heard very good things about twinscrolls but most of the after market ones seem kinda big
also the specs of the vf39 would be appreciated too thanx
azn_ryder02 is offline
Old 10-27-2006, 11:55 PM
Krinkov's Avatar
the VF36/37 compare almost directly to the VF30/34, they use he same compressor and turbine AR, the VF37 is sleave bearing like the VF30 and the 36 is roller bearing like the 34, the 36 also suposedly uses a lighter titanium turbine and shaft as well. All in all they wont flow anymore or make any more power than the single scroll 30/34, and while twin scroll is always benificial, on the 2.5 I have not seen any worthwhile difference in spool running these twin scroll versions compared to he single scrolls, these are already pretty small turbos!
the VF30/34 is rated at 435cfm at 1/bar dont have numbers for the 39, but its just a bit less
Krinkov is offline
Old 11-18-2006, 08:49 PM
other twin scrolls
are other twinscrolls other than aps tsr70 turbo thats larger than stock??
Old 11-19-2006, 03:33 AM
Krinkov's Avatar
the aps TSR 70 is basically a twin scroll Garrett GT seriesd turbo, I dpnt know the exact specs but it looks to be about GT35 sized. If your not married to the idea of having the APS name brand tacked onto a Garrett turbo, you can get any of those Garrett GT series turbos with a twin-scroll turbine housing from ATP for alot less $$$
http://www.atpturbo.com/
Krinkov is offline
Old 11-19-2006, 09:21 PM
thanx. how big is the gt30 compared to say a 20g? is there smaller twin scrolls available?? sorry, i appreciate the info dont have much experience w/ turbos. the aps guy said that the tsr70 hits boost at 3500 is that possible??
Old 11-21-2006, 12:26 AM
Krinkov's Avatar
the GT30R is much bigger than either of the 20Gs, the GT3071 is a bit smaller but still bigger. TD06 20G should be around GT2871R size, though I dont think they make a twin scroll for those, though a GT2871R would already spool pretty doan quick enough on a 2.5
Im not sure what size compressor wheel the APS one uses, but from what I hear its comparable to a GT35, which is way bigger than I like but thats just my pov.
and the "hits boost at 3500" is completely irrelevent. What boost? 1 psi? 14.7 psi? 20 psi? And regarless keep in mind that trying to measure spool up by what RPM a turbo hits xx boost is useless, since what we experience as lag is the amount of TIME not rpm it takes for turbo to spool up, you can have a small turbo and large turbo both hit say 15psi at 3500 RPM, but the larger turbo will take more time (lag) to get up to that 3500RPM/15psi level.
Krinkov is offline
chochocho
02-24-2012 04:09 PM
calisti
Subaru OEM Parts For Sale
04-22-2009 12:16 AM
outcast
04-24-2006 09:17 PM
typer_126
10-31-2004 04:01 PM
typer_126
Wanted
10-31-2004 08:08 AM
Quick Reply: does anyone know the VF36 turbo specs?
