CEL with a flashing Cruise light - Dead Battery?
Old 04-12-2012, 04:23 PM
tombo's Avatar
Car Info: 04 JBP STI
So today I started up my STI, let it sit for about 2 min at idle, and then started to drive off. Everything was fine until I noticed that the idle began to get low and rough and there was no response when I hit the gas pedal. Instantly I received a CEL with a flashing Cruise light. I tried to read the code with my AP, but it states there are no codes to read. Does anyone know what is going on? My battery is practically dead I might add since it's about 6 years old and I just changed my plugs 600 miles ago.
tombo is offline
Old 04-12-2012, 04:42 PM
Nobody likes the tuna here
Heedz's Avatar
Location: Somewhere San Mateo County, Inside A 911 Ambulance
LIMP MODE!!!! Thats all.
Try a different reader. Any other symptoms.
Heedz is offline
Old 04-12-2012, 05:40 PM
tombo's Avatar
no other symptoms. I'm going to just reset the ecu and see if it occurs again, as well as replace the battery (as if it has anything to do with it)
tombo is offline
Old 04-15-2012, 08:16 AM
Heedz's Avatar
Make sure your intake box is sealed fully too.
Heedz is offline
Old 04-16-2012, 03:41 PM
tombo's Avatar
I have a k&n typhoon intake, could it possibly need to be cleaned?
tombo is offline
Old 04-17-2012, 08:34 AM
Volkey's Avatar
Car Info: A Dirty Car
You need to stop driving the car if you have a CEL & flashing cruise asap. If your AP/Engine Management tool can not read the code, you need to disconnect the Negative terminal on your battery. While it is disconnected, pump your brake pedal a few times, then re-connect your terminal on the battery..
Everything should be back to Normal now. If it continues to happen, I suggest getting your car checked. However, every once in a while, my car also throws a CEL with no code to be read. Just clear it and be on your way.
Volkey is offline
Old 04-25-2012, 08:18 PM
iClub Silver Vendor
EQ Tuning's Avatar
Car Info: A Laptop
The AP will not read some codes. You can use a standard code reader to pull them up.
-- Ed
EQ Tuning is offline
Racerkid
05-29-2012 06:16 PM
06scooby
10-15-2006 10:11 AM
2005WRXST!
11-20-2005 11:23 AM
digitsti
03-29-2004 03:40 PM
DaveWRX
09-18-2003 12:49 AM
Quick Reply: CEL with a flashing Cruise light - Dead Battery?
Top
