Brian crower stories
I personally know quite a few people running their full valve train or just the cams alone. No issues at all. The only thing is that there aren't true 272 cams compared to other 272 cams like GSC or Kelford. Samething with the 280s. However, from a reliability point, haven't heard of the bc stuff having issues. The ones that do have issues, probably didn't install them correctly.
Car Info: 2012 WRX limited
So just use a different cam provider then? That's not bad. Yeah I was hearing stories from people who had cams snap on them so I was wondering how true that could be or was it user error.
Technical Know-It-All
Car Info: '02 WRX + '15 WRX
Their cams give you the bad idle you want and none of the power that's supposed to go with it. And they have a history of cracking and not fitting properly. I've also heard shops tell tales of their valve springs not being consistent and killing engines. I don't know any examples of their springs personally.
A friend's shop refused to sell BC.
Good cams are GSC, Cosworth, and Kelford. I chose GSC because Kelford and Cosworth (made by Kelford) have had some reduced quality issues over the last few years. Stay away from Supertech valvetrains.
Well eventually I would like to get some beadwork done with the striker kit but my friend has to replace cylinder 3 piston ring so he was looking around for some pistons and rods while he was in there and I recommended BC but he was saying that he thought they were all bad
James1980
Engine and Drivetrain
20
03-02-2010 11:12 AM
maperformance
98
09-30-2009 08:52 AM
SBR Chris
04-09-2007 02:00 PM
