Anyone have a 12\13 wrx with a catless dp havinng issues
Old 06-27-2013, 01:42 PM
subiED's Avatar
Car Info: subaru wrx 2013
I wanna get a catless dp but ive heard boost creep problems does any one have a 12\13 wrx with one on at can actually say if they do or dont have boost creep
subiED is offline
Old 06-27-2013, 03:45 PM
b-weezy's Avatar
Car Info: 2012 WRX limited
I have the catted Cobb dp and I still boost creeped until I put it on the stage 2 SLWG Acn map. Runs perfect now. Just waiting for my protune. I have a 2012
b-weezy is offline
Old 06-29-2013, 12:59 AM
subiED's Avatar
Yea i have the catted dp and header up pipe and invidia exhaust on my 13 wrx
And wanted to try the catless dp just didnt know if any has tried it
subiED is offline
Old 06-29-2013, 04:02 AM
Nobody likes the tuna here
Heedz's Avatar
Location: Somewhere San Mateo County, Inside A 911 Ambulance
the VF52 is known for boost creep.
Heedz is offline
Old 06-29-2013, 11:41 PM
brewsky79's Avatar
Car Info: his wife crazy
Catless DP = very little exhaust backpressure = boost creep (w/o proper boost control)
Without backpressure, it's very easy for a turbo to hit target boost and exceed it. There are a couple of ways to combat this. First, you can get a tune that will optimize your wastegate duty cycle values and open the wastegate a little more just prior to hitting boost target (Note: Changing your stock 2-port EBCS to a 3-port EBCS will not help boost creep and is dangerous to your motor w/o a proper tune). Second, you can go EWG. EWG is much more stable at controlling boost creep and holding boost target than IWG. The only problem with EWG is the fact that most setups out there are venting to atmosphere which attracts the wrong attention (policia!). Third, you can actually port the IWG on your stock turbo to flow the exhaust more efficiently than stock. However, I've seen problems with that in the fact that the turbo (BCS rather) tends to hunt for the boost target. It will fluctuate because of the improved air flow through the IWG. I would rather go EWG, but it is still an option.
Hope this helps!
brewsky79 is offline
Old 07-09-2013, 11:05 AM
subiED's Avatar
subiED is offline
Old 07-09-2013, 08:38 PM
Heedz's Avatar
you just gotta have a very controllable right foot.
Heedz is offline
rau
04-14-2011 01:28 PM
Irish_car_B0mb
08-02-2010 09:21 PM
wrxgirl08
02-06-2010 04:59 PM
STiYLIN
05-19-2007 10:07 PM
WRXWagon203
07-05-2004 10:58 PM
Quick Reply: Anyone have a 12\13 wrx with a catless dp havinng issues
