Go Back   i-Club > Engine and Drivetrain Tech Forums > Engine/Power - EJ20T (pre-2006 WRX and JDM)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Welcome to i-Club
Reply
LinkBack Thread Tools Search this Thread Display Modes
Old 09-09-2004, 09:50 PM   #1
Personal Sales Rating: (6)
Drives : e92 335i
VF22 boost issues
Okay, I've been searching and I've found tons of good info. The only problem is I have no clue what is going on! All I can say is the car was driving fine this morning, this afternoon while driving home I had to suddenly accelerate to take my exit, boost was still normal. Got off freway and stopped at light, light turns green and I noticed that my car is only boosting 5-6psi. Next light I take off a bit hard to check it out again and only 5-6psi till 5000rpm then POW 18psi till redline...I checked all hoses and everything if fine, my car has been in its current state for a few months w/no problems. I'm thinking the wastegate might have been stuck??? anyone have this happen to them?
engine mods:
vf22/upgraded injec./pump
ecutek
txs fmic
apexi short ram
gruppe-s up/helix dp/ tanabe catback
Oh, I've checked out the wastegate and it seems to open and close fine, I also checked out the boost solenoid and it seems fine.
Just fishin for some clues here....
Offline
Old 09-09-2004, 10:06 PM   #2
Personal Sales Rating: (12)
Drives : 1993/2000/2001 GF4 mostly red
Points: 33,076, Level: 100
Points: 33,076, Level: 100 Points: 33,076, Level: 100 Points: 33,076, Level: 100
Level up: 0%, 0 to go!
Level up: 0% Level up: 0% Level up: 0%
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Send a message via ICQ to Kevin M Send a message via AIM to Kevin M Send a message via MSN to Kevin M Send a message via Yahoo to Kevin M
It's definitely a wastegate issue. Either your boost solenoid is malfunctioning or the wastegate itself is hanging up.
Offline
Old 09-09-2004, 10:21 PM   #3
Drives : e92 335i
Well ,I'm guessing the next step would be to take the dp off and check the internals. Any ideas on how to check the solenoid for a malfunction?
Offline
Old 09-10-2004, 02:39 AM   #4
Daily Activity: 0%
Borrow one from a friend.
Offline
Old 09-10-2004, 10:47 AM   #5
Personal Sales Rating: (2)
mmboost's Avatar
Drives : Mazda5 stuffed with carseats
Send a message via AIM to mmboost Send a message via Yahoo to mmboost
Here are some things I tried in ruling out such problems before confirming I needed to port the wastegate. (I'm not saying you need to port, since I dunno if vf22s suffer the same problems that vf34s do... anyhow...).
- With the car off, put a compressor to the actuator and see if it moves. Just give it the normal absolute pressures you'd find coming out of your compressor under boost... so like 20 to 30 PSI. The actuator arm should move forward and you prolly could hear the gate snap shut when you cut the pressure. If the actuator arm doesn't move, the actuator is prolly faulty
- borrow someones working stock solenoid. very easy to remove and install. if the problem goes away, your solenoid is prolly the culprit.
- if the actual flapper of the gate was broken, you probably pushed it out your 3" tail pipe
jason
Offline
Old 09-10-2004, 01:26 PM   #6
Drives : e92 335i
Just wanted to thank you guys for all the good info....
Found out the problem!! It was from the TXS receric BOV that came with the FMIC. The little valve inside was stuck, I noticed this while I was taking off the piping to make room so I could get to the turbo. So I took off the BOV completly apart and sanded any rough spots inside & smoothened it up a little, added a few washers to make the spring a bit stronger. Took the car for a drive and no-mo-problems ......The End......
Offline
Old 09-11-2004, 01:01 AM   #7
mmboost's Avatar
thats unsettling...
Offline
Old 09-12-2004, 09:53 PM   #8
Personal Sales Rating: (1)
Drives : lowered blk04 with no motor
Send a message via AIM to GasPipe DreameR
im from pleasanton
Offline
Old 09-13-2004, 06:49 AM   #9
Personal Sales Rating: (0)
Drives : black my03 5mt wrx s/w
Points: 7,439, Level: 57
Points: 7,439, Level: 57 Points: 7,439, Level: 57 Points: 7,439, Level: 57
Level up: 45%, 111 to go!
Level up: 45% Level up: 45% Level up: 45%
Daily Activity: 0.7%
Daily Activity: 0.7% Daily Activity: 0.7% Daily Activity: 0.7%
i assume you did lube the bov before refitting?
Offline
Old 09-13-2004, 09:53 AM   #10
Drives : e92 335i
dabbed a bit of unused motor oil on the valve
Offline
Old 09-16-2004, 12:56 AM   #11
hey man how is the vf22 with the turboxs fmic?..i was thinking about doing that next to my car..how bad is the lag?
Offline
Old 09-17-2004, 01:37 AM   #12
Drives : e92 335i
lag is not really noticable(+200rpm at most) , I say go for it...My top end has improved way more than when i had the txs tmic.
Offline
I-Club
Subaru WRX
Paid Advertisement
Reply
Tags
boosting, issue, issues, problems, stopped, vf22, wastegate, wrx
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
-= NOT AUTHORIZED OR APPROVED BY OR AFFILIATED WITH SUBARU OF AMERICA OR FUJI HEAVY INDUSTRIES LTD. =-
