Go Back   i-Club > Engine and Drivetrain Tech Forums > Engine/Power - EJ20T (pre-2006 WRX and JDM)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Welcome to i-Club
Reply
LinkBack Thread Tools Search this Thread Display Modes
Old 04-23-2004, 06:51 AM   #1
Personal Sales Rating: (1)
Question Torque on block drain plugs?
I'm going to be trying to COMPLETELY drain my engine of the stock coolant mix to switch over to NPG+.
Anyone know what the torque specs are for the drain plugs on the bottom of the engine? (The two 14mm hex keyed plugs)
Offline
Old 04-23-2004, 08:07 AM   #2
ish
Personal Sales Rating: (7)
ish's Avatar
Drives : 2009 wrx & 2000 4runner
Points: 31,392, Level: 100
Points: 31,392, Level: 100 Points: 31,392, Level: 100 Points: 31,392, Level: 100
Level up: 0%, 0 to go!
Level up: 0% Level up: 0% Level up: 0%
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
Send a message via AIM to ish
those bolts get tightened to 50.6 ft-lbs
however when draining the coolant system, you don't need to access the "service hole plugs"
Offline
Old 04-23-2004, 09:22 AM   #3
Post
Thanks for the info...
I figured that I would need to use those drains if I wanted to actually get almost every drop out of the whole system.
(I'm replacing my coolant with NPG+ which is NOT compatible with water...)
Offline
Old 04-23-2004, 08:11 PM   #4
vteg
Are you going to have to let the engine air dry
Old 04-23-2004, 09:26 PM   #5
Personal Sales Rating: (9)
mexicanpizza's Avatar
Drives : MMVI AW WRX STI
Send a message via AIM to mexicanpizza Send a message via Yahoo to mexicanpizza
I thought about doing that...but the complete drain sounded like a pain. Doesn't the water rise to the top and you can just suck it off?
Offline
I-Club
Subaru WRX
Paid Advertisement
Reply
Tags
06, block, drain, plug, plugs, spec, torque, wrx, wrxblock
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
-= NOT AUTHORIZED OR APPROVED BY OR AFFILIATED WITH SUBARU OF AMERICA OR FUJI HEAVY INDUSTRIES LTD. =-
