Go Back   i-Club > Engine and Drivetrain Tech Forums > Engine/Power - EJ20T (pre-2006 WRX and JDM)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Welcome to i-Club
Reply
LinkBack Thread Tools Search this Thread Display Modes
Old 04-19-2004, 10:05 PM   #1
Personal Sales Rating: (6)
Drives : 2004 Black WRX wagon
reseting ECU after mods..
hey, i hear that we are supposed to reset our ECUs after each mod... How is it beneficial? if it is, how do i do it? thanks guys.
my bud has some bolt ons and he's never reset his ECU...
Offline
Old 04-19-2004, 10:41 PM   #2
does resetting reset milege?
Offline
Old 04-20-2004, 01:02 AM   #3
Personal Sales Rating: (4)
Points: 12,313, Level: 72
Points: 12,313, Level: 72 Points: 12,313, Level: 72 Points: 12,313, Level: 72
Level up: 66%, 137 to go!
Level up: 66% Level up: 66% Level up: 66%
Daily Activity: 0%
Daily Activity: 0% Daily Activity: 0% Daily Activity: 0%
reseting the ecu pretty much makes the ecu relearn everything instead of waiting for it to slowly adjust.
a search will give you alot more info.
Offline
Old 04-20-2004, 12:23 PM   #4
Personal Sales Rating: (1)
Drives : 2002 WRB WRX
drkicker
Send a message via ICQ to DrKicker Send a message via AIM to DrKicker Send a message via MSN to DrKicker Send a message via Yahoo to DrKicker
Quick rundown. Disconnect negative side of battery, press brake pedal until taillights go out. Reconnect battery. Drive aggressively for the next 50 miles for a more aggressive learn. I made a huge difference to do this after my downpipe was installed.
Also, it only resets your trip odometer.
Offline
Old 04-20-2004, 12:29 PM   #5
Personal Sales Rating: (9)
mexicanpizza's Avatar
Drives : MMVI AW WRX STI
Send a message via AIM to mexicanpizza Send a message via Yahoo to mexicanpizza
You could also perform the "Vishnu Reset" that will instantly max out the timing advance so you don't have to wait for learning. Search for how to do it, it's pretty simple.
Offline
Old 04-20-2004, 01:39 PM   #6
awns729's Avatar
Drives : want a WRX
Points: 14,048, Level: 76
Points: 14,048, Level: 76 Points: 14,048, Level: 76 Points: 14,048, Level: 76
Level up: 99%, 2 to go!
Level up: 99% Level up: 99% Level up: 99%
Daily Activity: 0%
Send a message via AIM to awns729
Well, driving aggressively for the first 50 miles probably yeilds similar results, but the vishnu way is most likely quicker. If you do reset it the only way you'll notice a power difference is if the ignition multiplier retarded timing due to knock(bad gas), otherwise AFAIK there shouldn't be any noticable difference.
oh and if the timing has been retarded and you do the vishnu trick it will advance the multiplier to + 12-i think (default after reset is 8, vishnu trick increases it)...search for the vishnu advance multiplier trick which has all the info you need.
Offline
Old 04-20-2004, 07:14 PM   #7
thanks guys.
Offline
Old 04-20-2004, 07:15 PM   #8
awns729's Avatar
Drives : want a WRX
Daily Activity: 0%
so what are you planning to do?
edit: once you do it, let us know how it tuns out
Offline
Old 04-20-2004, 07:21 PM   #9
i have my cat. getting my up and down soon.
Offline
Old 04-22-2004, 07:17 AM   #10
Personal Sales Rating: (0)
Drives : black my03 5mt wrx s/w
Points: 7,439, Level: 57
Points: 7,439, Level: 57 Points: 7,439, Level: 57 Points: 7,439, Level: 57
Level up: 45%, 111 to go!
Level up: 45% Level up: 45% Level up: 45%
Daily Activity: 0.7%
Daily Activity: 0.7% Daily Activity: 0.7% Daily Activity: 0.7%
don't reset too much.
become accustomed to the feel of pulled timing... flat spots in the torque curve. they are your clue as to where knock is occuring, and that something isn't quite right. resetting your ecu to "cure" the problem puts your engine at more risk, since the knock will likely happen again, and it must before the timing is accordingly re-pulled.
your ecu will ALWAYS attempt to advance the IAM, and it will slowly readvance the learned knock zones... resetting just helps it along its way.
in case you haven't noticed, i am of the persuasion that the least amount of resetting the better. in the case of a bunch of modding to open intake/exhaust, then go ahead an do it.
jm2c
ken
Offline
I-Club
Subaru WRX
Paid Advertisement
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
-= NOT AUTHORIZED OR APPROVED BY OR AFFILIATED WITH SUBARU OF AMERICA OR FUJI HEAVY INDUSTRIES LTD. =-
