Rebuild or Replace Rear Differential?
Old 09-18-2014, 01:51 PM
de_engineered's Avatar
I needsa new diff. It grumbles, loudly, when I let off the throttle.
04 WRX, 5 speed, 140K on the odomter, car is a daily, some action here and there (absolutely no redline launches from a stop etc. though), don't expect to break 350 wheel horse after all planned mods and tune.
I am the 4th owner, and previously have had to deal with snake in grass problems from the previous drivers. Looks like another scaly is saying hi now.
Should I rebuild or replace?
Recomendations on where and/or how to go about doing that?
de_engineered is offline
Old 09-19-2014, 09:48 AM
wrxfamwagon's Avatar
Car Info: 2003 WRX Wagon
I just had to rebuild the rear diff on my 03. Spider gears took a crap, so I decided to throw a limited slip in it. I went with the Cusco 1.5 RS. Car drives great now, but slow tight corners it is loud as hell. It doesn't bother me too much, but she hates it. I tough about buying a used one, but you never know what condition it is going to be in. I'm in Santa Clara if you want to see what it sounds like.
wrxfamwagon is offline
Old 09-19-2014, 12:46 PM
At a glance the Cusco looks about $1300, and I haven't that kind of coin at present :[. Might be cool to check out nonetheless. I'm in downtownish San Jose.
Is the noise from some kind of dog gear setup in the dif? I find I don't know much about some parts of the car until I want to upgrade it or it goes wrong haha.
I'm down for a cheap/workable solution for now, hence the used/rebuild question.
Old 09-19-2014, 03:06 PM
Funks's Avatar
Car Info: STI Hatch - 2012
any reason why people are opting to buy Clutch Type LSD's instead of a Helical / Torsen type like Tomioka, or Quaife, Wavetrac? not available?
Funks is offline
Old 09-19-2014, 03:22 PM
Ye olde unabomber FAQ seemed to point to a Torsen differential for most applications, and others as more akin to coilovers. Look how many get coils just because.
Old 09-19-2014, 04:09 PM
Javirex23's Avatar
Car Info: 07lmtd 6spd wrx eq tuned
Just replace it
Javirex23 is offline
Old 09-19-2014, 06:06 PM
Originally Posted by Javirex23
Just replace it
For reasons of cost, convenience, or both? Not challenging your response, just curious why.
Anyone got a diff laying around ?
Old 09-19-2014, 08:16 PM
Javirex23's Avatar
Cost mainly.... You can find a wrx diff for fairly cheap... <200 dollars.... Unless you can rebuild it yourself and not pay mechanics rate.
You can find a few diff's for sale here or on nasioc. For reference I sold an r180 sti diff for 300 and that's about the price they go for. A wrx diff is much cheaper
Old 09-29-2014, 10:21 AM
I'm not sure what you decided to do, but I just switched over to the Cusco LSD oil after the 500 mile break in and it is quiet and smooth now.
Old 10-06-2014, 10:42 AM
Nothing yet, though I am gonna get a (hopefully) low milage diff to swap in sometime soon. Bills are killing me, had to pick up another job.
Good to know though. I had some issues previously with diff clunk (independent of any wear issues so far as I knew), which poly bushings and heavier fluid helped a lot with.
Goss408
12-03-2013 08:54 AM
Cody8675309
13
10-24-2013 12:33 PM
rad1
10-22-2005 01:15 PM
rad1
10-17-2005 06:56 PM
Wagon Joe
11-04-2003 10:12 PM
Quick Reply: Rebuild or Replace Rear Differential?
