Go Back   i-Club > Engine and Drivetrain Tech Forums > Engine/Power - EJ20T (pre-2006 WRX and JDM)
Sign in using an external account
Register Forgot Password?
Register Photos FAQ Members Search Today's Posts Mark Forums Read ExperienceUsed CarsGarageVendors TSB & Recalls
Welcome to i-Club
Reply
LinkBack Thread Tools Search this Thread Display Modes
Old 11-14-2004, 01:18 AM   #1
Personal Sales Rating: (0)
Drives : 04 black wrx
Send a message via MSN to imprezilization
Unhappy knocking, because of the uppipe?
just put on my helix uppipe. car sounds great! but it started to detonate around 5000 rpm(w/ full tank of gas). it even threw me a flashing chech engine lite! but it went away. i already had the helix down pipe, cai and greddy evo and worked great before. never heard of anybody getting knocking from bolt on exhaust parts.
makes me worry!
Offline
Old 11-14-2004, 06:13 AM   #2
2003wrx64
Do you have any cats left on the vehicle? If not, your check engine light is probably due to the 2nd O2 sensor sensing that the catalysts are performing below par. Also with an uppipe install it is neccessary to install a resistor that fools the ecu into thinking that the temperature within the uppipe is in the proper range. In the first case, you can drive the vehicle with no issues. In the second, the ecu will probably go into safe mode, causing a drop in performance.
Old 11-14-2004, 12:34 PM   #3
its definitely not the first case, forgot to tell u, i got a cel fix for the second o2.sorri. i dont think its the second case ether, im sure it was detonation, although i would like to learn how to take care off the temp sensor. i think i will take off the cai and see, that might be the problem.
Offline
Old 11-14-2004, 04:26 PM   #4
Drives : 2004 Black Wrx
Send a message via AIM to BlkRx
I think that the cai is your problem. It is never a good idea to use a cia in a wrx. If you look around on this board you will see numerous posts which dismiss cia's and go into some in depth discussions about the possible negative reprecusions of using them. It essentially comes down to it leaning out the engine and causing detnoation. I would ditch the cia right away and Id be willing to bet youll be alright. Good luck.
Offline
Old 11-14-2004, 11:19 PM   #5
Talking
yep, just took off the cai and went for a testdrive. problems gone. floored in 1st, 2nd and 3rd to redline, no knocking what so ever.
Offline
I-Club
Subaru WRX
Paid Advertisement
Reply
Tags
2003wrx64
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO ©2010, Crawlability, Inc.
-= NOT AUTHORIZED OR APPROVED BY OR AFFILIATED WITH SUBARU OF AMERICA OR FUJI HEAVY INDUSTRIES LTD. =-
