Adjusting TD04 Wastegate
Old 08-23-2005, 10:59 PM
Dynapar's Avatar
i have heard you can adjust the wastegate ona td04 so it will only push 6-7 PSI.
does anyone on here know how to do this? if so can you please tell me. i have done no work with turbos, and want the smallest amount of boost out of the td04.
Thanks for the help.
Dynapar is offline
Old 08-24-2005, 08:18 AM
andrew12's Avatar
Car Info: 2004 jbp wrx
most peple only adjust the arm with the intentions of decreasing wastegate flutter experienced after losing some backpressure from the installation of aftermarket downpipes. if you over tighten then it will have boost spikes, dont know, but you could try twisting it in the opposite direction to tightening, but i really dont belive that that would be a good thing to do. search scoobymods.com for wastegate arm and you will find the thread with pics... if you have an accessport you could run the economy mode map which is supposed to limit boost.
chile
andrew12 is offline
Old 08-24-2005, 10:16 AM
slvrsubywgn's Avatar
Location: EBAIC- Wondering if I should have taken the blue pill...
Why would you want to mechanically limit boost that low? Just for better gas mileage?
slvrsubywgn is offline
Old 08-24-2005, 11:24 AM
Dynapar's Avatar
i am going to be putting the turbo on a NA car, and well 13-14 psi on high compression = BOOOOOMMMMMM!!!!!!!! so 4-6psi on high compression = driveable.
Dynapar is offline
Old 08-24-2005, 11:55 AM
xitonedefix's Avatar
Car Info: 1993 Impreza L EJ20 Turbo FWD
i ran 7-8psi on my EJ18 and then an EJ22E and it drove fine all day.
the only reason wrx's run 1bar is because the have boost controllers built in the the car.
if you completely connect the wastegate to a vacuum source it will only run somewhere between 6-8psi on a td04l
xitonedefix is offline
Old 08-25-2005, 10:18 AM
Dynapar's Avatar
so if connect a line directly from the compressor housing to the wastegate it will only puch 6-7?
did you run an timing/ignition controls at 7-8psi or did you just dump fuel at it?
Dynapar is offline
Old 08-25-2005, 10:22 AM
yes, direct connection to the compressor housing wont throw much boost.
i was using 370 injectors with an APEX'i S-AFC and a 4bar dodge daytona turbo Fuel Pressure Regulator (free out of a junkyard)
I have an Split Second Timing Map Controller -01, but i never really used it.
Old 09-11-2005, 12:59 PM
Dynapar's Avatar
what would happen w/ a tock ej22 FPR? would it just not flow enough?
Dynapar is offline
Old 09-11-2005, 06:07 PM
it depends what injectors / fuel pump you use.
Old 09-12-2005, 11:30 AM
Dynapar's Avatar
i got some options there.
Stock ej22 fuel pump
WRX fuel pump (will probably put in, unless bad things happen form it)
220cc/min ej22 injectors
360cc/min ej22t injectors (probably will use)
XXXcc/min nissan 300ZX Turbo injectors (havent been able to find out what these flow, but its alot ie 600+cc/min)
Dynapar is offline
Old 09-12-2005, 11:40 AM
im running a wrx fuel pump, i was on the legacy turbo 370's. i got a little fuel cut between 4-5Krpm, but with the 4bar FPR, it went away.
I also ran STi 550's but they eventually started failing (staying stuck open) do to using stock managment.
but thats chaning soon.... muahhahaha
im proby going microtech, putting the 550's back in after that.
Old 09-12-2005, 11:53 AM
Dynapar's Avatar
so you just got a 4bar FPR? do this come on any subies? or can they be gotten aftermarket?
Dynapar is offline
Old 09-12-2005, 12:56 PM
Dynapar's Avatar
is the FPR the same as an FMU fuel management unit?
Dynapar is offline
Old 09-12-2005, 10:02 PM
mine was off of a old dodge daytona turbo, the stock FPR is 4Bar, but i just drilled out the stock EJ18 FPR and put it 'in line' of the fuel line.
any aftermarket adjustable fpr that you can find for a subaru should be adjustable up to that rate though.
Old 09-12-2005, 10:03 PM
im not familiar how the FMU works, i was under the impression that is uses some sort of computer control, but i may be wrong...
Quick Reply: Adjusting TD04 Wastegate
