FP GREEN 8CM Combo! EJ25 Turbo Engines, Greddy EVO 2 (STI), Gruppe-S Headers!
Hey guys,
The FP Green 8CM is back!!
FP GREEN 8CM, Helix 860cc Injectors, Cobb AP super Combo!
-FP Green with larger 8CM housing
-Helix 860cc Injectors
-Walbro Fuel Pump
-Cobb AP 2004 STI only
$2499 Shipped!!
Add $50 for other cars
Add $100 for all other Drive-by-wire cars (2005+ STI, 2006 WRX)
Oil / Water lines additional $75
Hey guys we just got in a large shipment of JDM EJ25 engines today! We have:
EJ25 Legacy Turbo Engine
-Virtually identical to USDM STI 2.5 Engine
-Less than 10,000km on engine
-Includes intake manifold, cam gears, sensors, water/oil pump, semi complete engine
-Leak down tested, At least 88% compression across all cylinders (factory is 80%+)
-Awesome for WRX engine swaps
$3499 + shipping
EJ25 Legacy Turbo Long Block Only
-Long Block Only
-EXCELLENT Compression, 93+% compression across all cylinders! (factory is 80%+)
-Crank position sensor holder is damaged, will require fabrication or will work with aftermarket crank position sensor (such as Motec, Tec III, and other stand alone ECUs)
$2599 + shipping
2006+ Plastic Coolant Reservoir
-Lighter plastic construction
-Used
$60 shipped
GREDDY EVO 2 Exhaust for STI
-High Flow Design
-50 State Legal
-Best balance between power and excessive noise!
$569 Shipped!!
Gruppe-S V2 Header
- 4-1 Investment Cast Collector
- NO low-end loss on 2.5 cars
- Gains of over 20 ft/lbs seen on modified STI's!
$399 Shipped!! (4 pcs left)
Please give me a call if you have any questions or would like to order. Thanks!!
Randy
randy@gruppe-s.com
510-783-5300
-Walbro Fuel Pump
$2499 Shipped!!
$3499 + shipping
-Long Block Only
$2599 + shipping
-Used
$60 shipped
-High Flow Design
-50 State Legal
$569 Shipped!!
Gruppe-S V2 Header
Randy
randy@gruppe-s.com
510-783-5300
Originally Posted by my sti 1
how much more whp will i get compared to the standard fp green with standard housing?
Please clarify, what do you have on your car? What are you comparing to?
-Thanks
Car Info: 04STiGT35rC16
-Thanks
-Thanks
thanks.
when i had my car tuned at gruppe-s i had a fpgreen, FMIC, 850cc injectors, big maf and was tuned on 100 octane and got 360whp. if just the turbo were to be swapped for the 8cm green how much more whp would i be able to get roughly?
thanks.
thanks.
Hello,
Those are really great numbers! We expect you to see an extra 10whp by switching. The beter news is that we now have Helix downpipe and the Gruppe-s header, so you may want to explore options like those
-Randy
AdamBOMB_STi
02-07-2007 01:47 PM
gruppe-s
Engine and Drivetrain
10-18-2006 07:46 PM
gruppe-s
10-16-2006 04:23 PM
gruppe-s
09-29-2006 10:12 AM
