Going nuts trying to id JDM motor
Old 07-29-2004, 09:51 PM
Admin v2.0
Imprezer's Avatar
Car Info: 02 Black Legacy GT
I spent the last two days doing research on the motor I got to mess around with.
The engine is EJ207DW4ER-026
The heads are LHS20V and RHS20V
The ECU is AH970
BUT...
No red intake pipe.
VF30 turbo.
STi optional oil temp/pressure adapter under the oil filter
Based on the ECU, it is a V7 STi RA Spec C
Based on the engine code, it is V7 STi RA Spec C, limited, or S202
But why VF30?
And it cannot be S202, since there is no red intake pipe
And, why is there STi oil temp/press adapter (of course, it could have been added after, but some STi came with it, so it could be a clue)
In terms of the heads, I am confused.
What do you guys know about it?
Imprezer is offline
Old 07-29-2004, 10:07 PM
Admin v2.0
Imprezer's Avatar
Oh yeah, I promise you all I will get to the bottom of this and will make a complete run down on all this mumbo jumbo.
Imprezer is offline
Old 07-29-2004, 10:11 PM
NASIOC Slut
Kostamojen's Avatar
Shoot, my two EJ identification links arent updated for newer motors...
But I did find some info via google.
A (MY01 - New Age Body Style Rev 1, V7 )
00/08-01/08
WRX NB (5mt) GDAA4CD - EJ205DW3BE
WRX NB (4et) GDAA4CT - EJ205DW3BE
WRX Sti GDBA4EH - EJ207DW3CR
WRX RA-Sti GDBA4DH - EJ207DW3CJ
20K (wagon 5mt) GGAA58D - EJ205DW3BE
20K (wagon 4et) GGAA58T - EJ205DX3BE
Sti (wagon) GGBA5EH - EJ207DW3CR
B (MY02 - New Age Body Style Rev 1, V7)
01/09-02/10
WRX NB (5mt) GDAB4CD - EJ205DW4BE
WRX NB (4et) GDAB4CT - EJ205DW4BE
WRX NB-R GDAB4HT - ??????????
WRX Sti GDBB4EH - EJ207DW4CR
WRX STi-RA spec C GDBB4FH - EJ207DW4EJ
WRX STi PRODRIVE GDBB4KH - ??????????
WRX STi LIMITED GDBB4JH - ??????????
S202 STi version GDBB4FH - EJ207DW4ER
20K (wagon 5mt) GGAB58D - EJ205DW4BE
20K (wagon 4et) GGAB58T - EJ205DX4BE
Sti (wagon) GGBB5EH - EJ207DW4CR
C (MY03 - New Body Style Rev 2, V8)
02/11-
WRX (5mt) GDAC48D -
WRX (4et) GDAC48T -
WRX Sti GDBC4EH -
WRX STi spec C GDBC4FH - EJ207DW5EJ
WRX Wagon (5mt) GGAC58D -
WRX Wagon (4et) GGAC58T -
Kostamojen is offline
Old 07-29-2004, 10:15 PM
MJU1983's Avatar
Car Info: 06 Armada, 03 WRX, 05 STi(sold), 05 Vette (sold)
RA Spec C Limited Alex.
Maybe it will make more power than your Axis motor, muwahahaha
MJU1983 is offline
Old 07-29-2004, 10:19 PM
NASIOC Slut
Kostamojen's Avatar
Are there any other markings on the heads?
Old 07-29-2004, 10:22 PM
Admin v2.0
Imprezer's Avatar
Yeah, I saw that.
According to that it is S202 engine. But then again, where is the red pipe? Why is VF30 there?
Hehe, this motor is not to replace the Axis monster motor. I decided to get rid of TEC III and in order to run OEM/STi ECU again, I have to re-wire the car (again) as I have removed my COMPLETE car harness from the car. And, after that, I am sure I will need to do some troubleshooting. And, I dont want to troubleshoot on the 10k motor.
After the car is re-wired, I will use the JDM motor for a while. Plus, I gotta get the Axis motor o-ringed. Then, I will use the AXIS and use the JDM one in my Legacy.
Imprezer is offline
Admin v2.0
Imprezer's Avatar
Lhs20v 006
Rhs20v 008
Imprezer is offline
Old 07-29-2004, 10:24 PM
NASIOC Slut
Kostamojen's Avatar
Got some more info:
WRX-NA 155ps/20kg-m non-turbo
WRX-NB 250ps/34kg-m TD04 turbo
WRX STi 280ps/38.0kg-m VF30 turbo
WRX STi limited 280ps/39.4kg-m VF30 turbo
WRX STi typeRA spec-C 280ps/39.4kg-m VF34 turbo
WRX S202 320ps/39.4kg-m VF34 turbo
*above are sedan. below are wagon
I's 1.5 liter non-turbo
20N 155ps/20kg-m non-turbo
20K 250ps/34kg-m TD04 turbo
Sports Wagon STi 280ps/38.0kg-m VF30 turbo
Old 07-29-2004, 10:28 PM
Admin v2.0
Imprezer's Avatar
Hmm, based on my turbo then, it could be regular STi, STi Limited.
Cannot be true.
Imprezer is offline
Old 07-29-2004, 10:29 PM
NASIOC Slut
Kostamojen's Avatar
Ok, the 006/008 = RA Spec C, but yes, the intake manifold/turbo is VERY confusing...
Old 07-30-2004, 06:25 PM
qwk_wrx's Avatar
Car Info: 05' Evo 8
still a bad *** engine none the less...
qwk_wrx is offline
Old 08-05-2004, 09:57 PM
Admin v2.0
Imprezer's Avatar
Ok, did some more research and with huge help from Yohei (gogogo) I found out the following.
First some background info on GDB STi's in Japan.
The GDB's went through A ~ E type. A being the first one when it was introduced as MY01.
GDB A-revision, they had the following STi's:
STi -- EJ207DW3CR (VF30)
STi Type RA -- EJ207DW3CJ (Same as regular STi, no AC, no power options, etc, VF30)
As you can see, the only difference is the last letter. And, I know that the engines were the same, besides the Type RA not having the AC there. So, my conclusion is that R= AC, J=NO AC.
GDB B-revision, they had the following STi's:
STi -- EJ207DW4CR
STi Prodrive Style -- EJ207DW4CR (Same as regular STi + added options)
STi Type RA Spec C -- EJ207DW4EJ (VF34, Spec C motor)
STi Limited -- EJ207WD4ER (same as STi Type RA Spec C + AC, power windows, VF30)
S202 -- EJ207DW4ER (Same as STi Type RA Spec C + Red intake hoses, special ECU, oil cooler, exhaust, VF34)
GDB C-revision, they had the following STi's:
STi
STi Spec C (No longer called Type RA Spec C)
STi Limited
GDB D-revision, they had the following STi's:
STi
STi Spec C
STi V-Limited (Same as Limited, but in the year when Subaru wins WRC, Limited becomes V-Limited)
GDB E-revision, they had the following STi's:
STi
STi Spec C
WR Limited
I am still working on the C~E revisions and will post this info soon. I did ID my motor by now, hehe.
My EJ207DW4ER is MY02 Subaru Impreza WRX STi Limited engine. Which is basically Type RA Spec C motor w/ AC. It is not a S202 like I was hoping, but it does not matter. The only difference would be the ECU, Red Intake pipe and VF34 instead of VF30 I got. The long block is identical. Weee-haaa!
Imprezer is offline
Old 08-05-2004, 10:47 PM
NASIOC Slut
Kostamojen's Avatar
Excellent! I figured the long block was the bestest, but the turbo + paint job isnt
Old 08-09-2004, 08:17 PM
BOXER4's Avatar
sounds like you have a very interesting motor.........did it actually come assembled like you received it?.........on the actual block, on the back side where the transmission usually meets the block on top, there should be a serial number of some sort....does it start with a "T", "R", etc.......also, did those heads come with that engine....."LHS20V and RHS20V"...usually SPEC C's come with "RHC" letters on the right head......also that ECU "AH970" is a Limited ECU with 320hp. the "AG970" is SPEC C......" AG971" is suppose to be the s202 sport ECU......
just some more info from my vault of useless info....
BOXER4 is offline
Old 08-09-2004, 11:19 PM
Admin v2.0
Imprezer's Avatar
Yep. It came like that.
As I found out, the head markings don't really have anything to do with it. Some are RHC and LHC, some are LHS20V and RHS20V. Some are mix and match.
I will look up the serial # tommorow. Why? What will that tell you?
Yeah, my AH970 is STi Limited.
STi Limited is basically a Spec C with AC and some other "power" options like windows and mirrors. And, it comes with VF30, so my motor is STi Limited for sure. Which is still a Spec C motor. Since it is going to be retuned anyways, I don't care if it is S202 or not. Engine is the same.
Imprezer is offline
Quick Reply: Going nuts trying to id JDM motor
